run_gmc
Sep 19, 2016Explorer
Yep... it's a "Power xxxxx" Whatever is after Power is covered with black paint. Reservoir is under the coach, near the Driver's side front wheel. Fluid is clean & "topped off". Legs sprayed with silicone. Pads & springs are relatively free of dirt. Cycled the system a couple of times, then tried to level in Manual mode. Same result... coach level from front to back,but not left to right. Going to try to re-calibrate level tomorrow. Don't remember seeing anything on the control pad, but will look again. Thanks!
38,769 PostsLatest Activity: Apr 03, 2026
