Floridastorm's avatar
Floridastorm
Mobile Repair - Positive or Negative?
Two Questions:
Prior to purchasing a used motor home I would think that it would be best to have a Mobile Repair Outfit go over the unit completely as, I imagine it is somewhat difficult to take the motor home to a maintenance shop and tie it up for the seller.
What kind of experience have any of you had with Mobile Repair?
Approximately what should it cost me for a technician to do a thorough job of checking and testing every part of the motor home?
Are most Mobile Repair Outfits competent to check and test every part of the motor home including all of the appliances? I would imagine if you're in that business then you probably can.
  • It cost me $200. to have the RV checked out. Tanks, appliances, water lines, slides etc.
    Then it cost me another $150. the have the mechanical checked out.
    But worth it.
