- Jim_n_StephExplorerWe had these installed in 250 of our tractors which was about half of our fleet . Ours would beep if you would leave your lane or wondering close the lane if no turn signal was used, if your following distance was decreasing you could set the following distance warning, speed limit . Most guys didnt like them due to beeping in city traffic or being cut off in merging traffic in light or heavy traffic
- Tiffin has offered it for about 4 years as an option. The only complaint my customers have is when in heavy traffic, the system is constantly beeping at you. The side and front proximity distance sensors react very quickly to Traffic around you. Doug
- wa8yxmExplorer IIIat under 1000 dollars. tell me more about this system 77.... Sounds like it might be interesting. also does it Pass-Through the OBD as I have something there already .
- 77rollalongExploreriam certified to install the mobleye system, you do need the software to program the system as well as the target plate to set the camera. most of the signals it does get from the OBD port
- Fla_Tom1ExplorerI like moble eye solely for the distance feature which is nice on the intestate. Ours was oem but does not look like a difficult install.
