Executive45
Sep 15, 2013Explorer III
The alarm is very sensitive. Did you fill the reservoir while the jacks were extended? If so, the res is probably too full. Too full will give you the same result as too low... I used to fill mine to the correct level, then I made my own "dipstick" using a tent stake. Put it in the reservoir top and mark the "full" spot. Makes refilling easy and accurate...disconnecting it could lead to an expensive fix if one of the jacks doesn't retract and you are aware of it...just sayin...Dennis
