cvbdsl wrote:
Billinwoodland wrote:
Came across this older thread when I was just looking at the Monaco. Ended up buying it. We have had one shake down trip, a few hundred miles. DW and I are very happy, and I think the advice I received here and over at the irv2 site was invaluable. I still need to get under the front end and see if the cheap fix was done. The coach handles really well so I have a hunch it has already been done. One thing I learned is that the dealer really did not know much about this coach. I did my homework (carfax, reading the forums, hired an independent inspector) and negotiated a good deal. I also was lucky that the previous owner took good care of the coach and kept up with the maintenance. This I discovered after finding some old paperwork in the coach during our first trip. Recently bought a used Vitara as a Toad since my other vehicles can't be towed 4 down. Now just need to get the base plate and supp brakes with break away installed. Fit and trim on the Monaco is superb, which I was somewhat worried about considering they were going broke when the coach was made. All is good, thanks friends.
Bill
Congrats on the new coach! If you're the least bit handy you can install the base plate yourself, lots good instructions from most vendors and YouTube videos - I did my last two and saved about $800 each time for the install, just take your time.
You'll find lots of good info on supplementary brake systems on this forum as well (everyone has their opinion on which is best!). I had the Blue OX Elite, but since I changed toads I went to the Patriot System, just because I had trouble getting a cable through the firewall and around the engine compartment in my 2013 Edge.
Don't forget to enjoy the journey!
Chris
Thanks Chris. I turn a decent wrench. I bought the blue ox base plate and the Ready brake system with their break away. Yes, I plan to install it myself. It does't look like rocket science. I found a blue ox alladin tow bar on Craigslist for $200 which was in perfect condition. For those using the Ready brake system with Blue ox tow bar, there is an additional part you need to buy to allow the brake cable to pass by part of the tow bar. The Hitch supply outfit was not familiar with that part so glad I had done the research.
Bill
