Dougjpr's avatar
Dougjpr
Monaco owners
For anyone who owns a Monaco or has owned one
Would you buy another? and why
Looking at a 2006 Cayman 40 PDQ, anything particular to pay attention to
Thanks
Doug
  • Like many others I have owned two Monacos, the first was a Diplomat and now a 42' Dynasty. I wouldn't even think of buying any thing else.
    I have been looking at a beautiful 05 Signature and would buy it in a second if I really was in the market. My rig is tight and rides like a Greyhound. Like Executive said, look the Cayman over very closely and ask lots of questions. Good Luck. Macktee
    In a heartbeat!
    and why
    We owned a Dynasty before buying the Executive. 110,000 miles on the Dynasty. Only problem we had was a blown hydraulic hose. We already have 85,000 on the Executive.
    Fit and finish is second to none. Strong quality coach. Mfg assistance is excellent, with service centers on both coasts.
    My experience has only been with the Dynasty and Executive, both luxury coaches. The Dynasty, Executive and Signature series, now the Camelot, Dynasty and Signature are considered luxury coaches and as such have steel cages. The other models have a composite framework. Check the Cayman closely. I think you'll find the cabinets are assembled using screws instead of staples. All body parts are assembled on tables and then put in place. BTW, you can contact Monaco at 800-509-3417 with the VIN of the coach you're looking at and they will email you the ORIGINAL build sheet for the coach. You can also go on line to Safercar.gov with the VIN to check for any recall and/or safety items.....Dennis
    Thanks
    Doug
  • The new Diplomat is also out there...but it is basically a rebadged and dressed up Fleetwood upper level DP...Mine is as solid as a rock and although there were issues, (including the Monaco legal mumbo jumbo), they were taken care of by the manufacturer of the components..it's one of the reasons we ended up keeping this coach rather than trading right now (that's a long story)...If the coach were maintained and kept up with , no reservations about the one you are looking at (note if it was the RR4R chassis, than the previous trailing arm issue brought up comes into play)
  • We owned a 2008 Monaco Dynasty, 42 ft., 4 slides, special ordering it and taking delivery in April of 2007. We drove it just shy of 70,000 miles in 7.5 yrs.. just selling it on consignment last summer (2014).
    Looking back, we had extremely good luck with it NEVER having anything major with the motor or drivetrain. I did need four coolant boxes including the original. Finally, I think the last one was made properly using non-defective material.
    We did have a couple of leaky windows (caulking seemed like a temp. fix) that I would probably have replaced if we had kept it. I would buy another Monaco product again. I'm not leaning towards the new style of the new Dynasty but the insides do look nice.
    When we started thinking about upgrading, I first looked at the Newmar King Air (beautiful coach), then the Newell coach and finally the Prevost. Buying a Prevost is a major commitment but I wanted the robustness of the best chassis on the market with real front and rear bumpers. They do seem to be built like tanks. Our exterior is made of a Kevlar composite which gives an extremely smooth surface.
    I think in 2008, Monaco started putting in flat screen TV's.
    The vibration going down the road seems to loosen screws, etc. I had to tighten my shower apparatus every couple of months.
    Good luck on your search,
    MM.
  • Monaco is on my short list of quality coaches:
    1) Monaco
    2) Beaver
    3) Newmar
    JMO of course. Based on resale value, initial quality, and serviceability. And reading consumer praise or complaints on forums like this for 12 years.
    I wouldn't turn down a nice Fleetwood Bounder though.
  • My Monaco is a 2012 gasser. I drove it out the door NEW loaded with extras I couldn't find on other brands for $100K. Electric heater in wet bay, EMS, heat pumps, air bed sofa, electric shades front, central vac, washer/dryer, heavy duty cargo doors. Had a few problems but Monaco took care of me very well and repaired warranty problems. I only had 3 warranty problems. Jacks, leaky front window, and broken bracket on gas filler hose. All repaired. Unfortunately they only make one model now. That will be the Dynasty. Dealer was dumping all Monacos because Monaco had financial problems. We're happy.
  • This may be one of the 4-bag chassis that need the replacement control arms.
    Check with Source Engineering at http://sourcerv.com/trailing_arm
  • We bought our Holiday Rambler (AKA Monaco Diplomat) new and would definitely buy another in that same time era. Never any major problems and love the 4 slides with the N/S bed floor plan.
    The Cayman has the 4 bag chassis, which is not the best riding of the Roadmaster chassis but is not that harsh. I do not remember if they had corrected the trailing arm problem by then, but I don't think they had, so make sure the trailing arms are the new style or plan on spending $5K on the first day, for the upgrade. That is a major major safety factor and I personally would not drive away from where it is parked, if the old style trailing arms are on the coach.
    Here is a link to the brochure for the 2006 Monaco Cayman .
  • We have a 2009 Holiday Rambler Endeavor SKQ and would definitely consider another Monaco product.
    Things we like:
    Fit and finish.
    Cummins ISL engine.
    Roadmaster chassis, great ride & NVH.
    Full body paint job excellent.
    Things gone wrong:
    All slide seals needed replacement.
    Dash audio system is greatly lacking.
    Shower valve knob broke.
    Otherwise "knocking on wood" very happy.
