Hummmmm, I've checked all the area underneath the plastic bin (near the passenger seat arm rest) that Mr. Mark and Ivylog mentioned. There is no kind of switch in there. I did find two extra seat belts in there that can be attached for the couch though.
crasster, I don't have an ash tray but there is a cup holder pull out tray about the center of my dash and a drawer underneath. Tomorrow I will try and figure out how to take the cup holder tray out and check inside there.
DSDP Don I can hear a little click in the dash when I hit the factory default code. It sounds like it's about in the area where that cup holder tray is located.
I re-read the manual regarding reprogramming the code. It says: Locate and press the Programming Switch located under dash panel". I have been looking under the dash but not the dash panel. It reads like I need to remove the dash faceplate and it is "inside" the dash somewhere. Hopefully I can get access to it when I get the cup holder tray out (if it's in there).
BTW, when I press the factory default code, I can hear a solenoid in the door trying to do something but it's not locking or unlocking using that code. I wonder; if it's been reprogrammed, does that somehow deactivate the factory code? If not, maybe the locking solenoid is shot and need replacement. I guess the solenoid is located inside the door. Anyone have any particulars with changing the solenoid or where to buy one. I'm sure I could get it from Monaco but maybe it's a generic part and could get it at an auto-parts house.
Thanks for the help so far.
