Dougjpr's avatar
Dougjpr
More Monaco questions
I seem to be posting a number of questions recently.
I am trying to get as much info as I can.
I understand that Monaco, HR, Safari and Beaver were all under the Monaco group in the 2005-2007 time frame that we are looking in. Is there anywhere I can find which models came from which plants? and were any of the Monaco plants better than any others?
Also with the number of Monaco and HR models is there somewhere I can find a list of which ones are their high end models and which are the lower lines, and which HR models are the twins of which Monaco models
Thanks
Doug
  • Thanks for the replies
    The list of Monaco and HR models is helpful (saves a lot of time looking at archived brochures and guessing)
    I thought the list on the back of brochure might be in order, but wasn't sure.
    The serial number info is helpful. I will look for that.
    I'm thinking that you may get better value buying the lower priced unit produced on the higher quality production line.
    Thanks
    Doug
  • I have a 2009 Monaco Camelot. A few years back I was inquiring about some parts with the Monaco tech folks, they use the last 6 digits of the unit serial number to identify the coach and look up it's history. The tech I was speaking with told me the first number of those last six indicates where the unit was built. In my case this number is 6 which indicates my unit was built in Coburg Oregon. He said he probably helped build my coach. I purchased this coach right after Monaco announced bankruptcy plans in April of 2009(got a great deal) and the dealer(DeMartini) told me that Monaco's higher end coaches are/were built in Oregon and the others in Indiana. I would believe if you have a serial number, a call to Monaco tech can tell which facility the unit was built in.
  • Holiday Rambler:
    Navigator
    Imperial
    Scepter
    Endeavor
    Ambassador
    Neptune
    Monaco:
    Signature-Navigator
    Executive
    Dynasty-Imperial
    Windsor
    Camelot-Scepter
    Diplomat-Endeavor
    Knight-Ambassador
    There were some other entry level models of that era.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Yes high to lower and I would put Camelot under Dynasty.
  • Thanks for quick reply
    I had downloaded a Camelot Brochure, is the list that is on the last page in an order high end to low end?
  • Monaco Brochures - Past years
    The higher end Monaco's:
    Signature - HR was Navigator
    Executive
    Dynasty
    Windsor
    Diplomat - HR model was the Endeavor
    Knight - HR model was Ambassador if I recall correctly
    Some of these were mid range depending upon what year.
