Goldencrazy wrote:
I had a 30T. It is light in the front anyway. If this were to work you would need to add some weight in the front which I am sure is doable but it will be more than just arranging normal cargo. I would think a nice lightweight trailer would do the job so much better. The lifts I see are usually there because the DP also is towing with an extended hitch.
Goldencrazy,
The Hydralift incorporates a 2" receiver, built right into the lift. In fact, it's tucked basically under the lift so, you have to watch your toad in tight corners so the lift floor, does not come close to the hood etc. of the toad during turns, dips, dip-and-turns etc.
Below is the way we used to do it. The Wing, hovering on it's lift, on the back of the coach, above the hitch which, towed the Jeep which, carried the bicycles. We looked like Jed Clampet cruising on down the road. But, as shown earlier in this thread, we now use the truck to carry the Wing.
