awolsmith's avatar
awolsmith
Motorhome water pump issue
Last time I used mh I drained the fresh waste tank. Went out to test for next trip coming up and pump didn't run. Found a fuse in back exterior passenger fuse panel it checked okay. Where might the water pump be and how else can I test it?
  • Updated found the unit that control the water pump out was behind the sewer dump. It had fallen and shorted out.
  • Monoplex pump controller......LINK
    Could be by 12V DC distribution panel, around converter, in compartment with water pump, inside a small outside compartment, behind drawers....it's kinda like a scavenger hunt, you just have to look in every conceivable place and then look some more.
  • It does have multiple switches, and it's a 2002 National Tradewind. Sounds like I need to find the pump. What dies the controlling unit look like?
  • IF you have more than one ON/OFF switch for operating pump then the 'pump controller' may be the problem
  • Be a little more specific, Make, model, yr. Some are under the sink, some in the fresh fill compartment.
