- FoodsmanExplorerYes both Newell and Prevost are aluminum skinned. Thanks Ernie...
- Boxer_LoversExplorerNewell Coaches are aluminum skinned I believe.
- ernieeExplorermy coach is a 97
the front and rear caps are fiberglass, whereas, the rest is steel - bshpilotExplorerShowhauler uses aluminum skin
- Passin_ThruExplorerAluminum and fiberglas are about the same when it comes to repairing. There are honeycomb fiberglas parts that are very strong and quite stiff. I worked on Raadomes and they were honeycomb. You took a pair of big pliars and pulled the dead Gooney Bird out, took a router and routed all the damage and then put in honeycomb and coverd it with fiberglas cloth, 3 coats of resin, 3 coats of filler and 3 coats of primer and 3 coats of paint. Very expensive repair and took a week to do it all.
- John_JoeyExplorerTake a look at Holiday Rambler Admiral, Endeavor and Presidential. I have an all aluminum HR 5'ver and am very impressed. I think those Class A's are what you're looking for.
- FoodsmanExplorerSteel... I didn't know that Ernie! How does that hold up and what year is your coach?
- ernieeExplorermy coach has steel
unfortunately Wanderlodge is not in business - rgatijnet1Explorer IIISome of the older Monaco coaches had aluminum skin, which included their Holiday Rambler line. Many of the fiberglass coaches have had delamintation problems. I am not sure that a fiberglass sidewall is any cheaper to repair than an aluminum sidewall if you have severe damage.
Even the Monaco brands with the aluminum sidewalls had a fiberglass front and rear cap. Aluminum/stainless steel front and rear skins might be limited to just the Prevost chassis. - mci7ExplorerHad a MCI and found the cost of maintaining aluminum skin, had a case where a UPS delivery van slid across the frobt of the bus, cost $26,000 to have repaired due to massive labor replavibg the structure in dash, front end, big job, bucking rivets etc.
Today have the Foretravel, fiberglass easy repair.
Dave M
38,707 PostsLatest Activity: Feb 18, 2025
