- EffyExplorer II
Disneyfix wrote:
Effy wrote:
I have looked at no less than 300 sets of these between Amazon and Ebay with prices from $19 - $80. How in the world do I know which ones to buy? I am looking for the 16ft, multi color (with soft white or dimmer) with remote, with power supply. Anyone find a good source for that? Tested and reliable?
These look decent and low cost.
Cheapos from Ebay
Hey Effy how do you like the shades of white in the RGB set?
Responded to your PM, but you can truly get any range of color on the ones I got. Everything from bright white (if you ever need that) to softer amber tones, red, blue, purple, pink and everything in between as well as dimmable. - paulcardozaExplorerThis
is what I got, with the IP67 waterproof rating. Yes, I spent more, but these lights are awesome. They can go from extremely bright to extremely dim and anywhere in between.
And they stick like glue with very good adhesive!
Worth the money to do it once and right. IMO - DisneyfixExplorer
Cheapos from Ebay
Hey Effy how do you like the shades of white in the RGB set? - MeffrigExplorerI too have purchased a set of LED lighting kit and am going to have Camping World install them. I could probably do it myself but I don't feel comfortable drilling thru my coach. I want to wire them to an inside electrical outlet or to my porch light. My concerns are: 1. I don't think my IR remote will work from the outside. 2. I am not sure that wire extension will be long enough to be able to do the hook up. Anyone dealt with Camping World on this type of installation? Thanks for your input in advance.
- EffyExplorer III went with these and although not installed yet I have tested at home. They work great. They also survived my 10 yr old son's rigorous "testing" as well. All buttons, modes, etc work as designed. I even tested them in the sink, and submerged they still worked. I am certain they will be just fine. The remote works wihout apparent line of sight so that's nice. For the price I couldn't beat it. The adhesive is the only lacking part, but A roll of 3m adhesive will solve that. Also, pay attention to the LED count. I noticed more expensive systems have 300 LEDs and this set has 150. I am ok with that and frankly they put out a lot of light so the 300 would be overkill in my opinion.
Funny I saw the EXACT same set at my local dealer the other day for $129.00. No kidding.
Lights - DisneyfixExplorerThanks Effy.
Any other testimonials out there. Sooo many choices when ya look on amazon. What manufacture did you guys go with? - EffyExplorer II
Disneyfix wrote:
Were they the 5050 outdoor model? Can the be spliced up into a few different sections and run into 12v light for instance? Or would I need a control box for each little section?
PS How did you guys get these tiny things to stay on the frame rails?
I think the plan is to buy a good roll of 3m adhesive. Yes got the 5050. I am not sure about splicing but they can be cut to fit. - DisneyfixExplorer
Effy wrote:
Disneyfix wrote:
Effy wrote:
So I received the lights yesterday. Tested them here in the house. THey work great. The remote does not appear to require line of sight. I tested from all angles and distances and it works fine. The adhesive stio that came on it appears to be worthless but I can buy a roll of that. So one final question on the install. I planned on attaching them directly on the wall of the coach just underneath the awning. Originally I had thought about running the power lead inside the awning mounting rail as my outside receptacles are right there and a bin right below that. The only problem with this seems to be that the power lead is really short. The 4 pin connector to the remove receiver is only about 3" long. So I either have to run the lights themselves down through the awning rail, or make a lead. I have never worked with the 4 pin connector lke that but I imagine I could splice it and run a length of it. How did you giys mount yours? I'd rather not drill into the wall if I don't have to.
So did ya go off ebay or amazon?
Bought the lights off ebay $29.00 including shipping. I got the extension 4 pin cord from Amazon for $7.00.
PS How did you guys get these tiny things to stay on the frame rails? - EffyExplorer II
Bought the lights off ebay $29.00 including shipping. I got the extension 4 pin cord from Amazon for $7.00. - DisneyfixExplorer
38,780 PostsLatest Activity: Nov 24, 2017
