dougrainer
Apr 06, 2018Nomad
That fuse protects the board from DC items on the refer that could destroy the board.
1. The Cooling fans(Most likely)
2. The tstat for the cooling fans
3. The inside optical board(On/off/temp set) and the wiring going to it
4. The LP solenoid valve
5. The heat strip for the optional icemaker line to the icemaker
6. The bottom inside refer doors divider strip heater
7. The interior light bulb assbly
You need to check the DC items before you spend money on a Board. I cannot remember EVER replacing a Board for the 5 amp dc fuse blowing. It has always been something on the Load side. Doug
38,763 PostsLatest Activity: Dec 05, 2025
