Black95
Jun 26, 2015Explorer II
Took my van to the local Chevrolet dealer to fix the inoperative right switch on the power driver's seat of my van. They installed a wire clip and charged me no labor as if it were fixed. It wasn't, so today I removed the seat so I could get at the mechanism of the electric seat. Took the mechanical connector apart from the screw device that moved the seat and discovered that it was just stuck in the up-position, almost like it was double-nutted. I worked it loose and applied a little WD-40 and some lube-grease and now the seat adjuster works perfectly. Don't know what caused it to get stuck, but now the problem is solved and my electric seat works in all modes again.
