Black95
Feb 02, 2020Explorer II
Hi Jay,
Here is the link for where I purchased my swivel seat. If you search the internet, I am sure there are several other places to get them also.
https://shop4seats.com/rv-furniture/rv-bases/class-c-rv-bases/gm-chevy-bases/96-gmc-chevy-aftermarket-seat-adapter-440.html
In answer to your next question about the wiring, I cut the wires and soldered in a new six wire connector after feeding the wires through the seat swivel hole in the center because no connector would fit through the center bolt hole on the seat swivel. I would suggest disconnecting the battery before you do the cutting and soldering. Here is a picture of the 6 wire connector I used. I had to buy them in a pack of five, so if you want one for the cost of mailing I will send you one. Send me your mailing address to me at [email protected]
I forgot to take pictures of the wiring before I mounted the seat and swivel, so here is a picture taken after the mount was installed. A is the connector wired in after the wires were cut and B is where the wires were threaded through the seat swivel hole before I soldered them to the 6-wire connector.
I will post more info on my GPS holder in my next update.
