Black95
Feb 25, 2021Explorer II
J herb wrote:
Mike, a nice setup to have as you can use a heater that doesn't have a thermostat, if needed can you run both heaters on low at the same time?
Hope that you are able to go camping soon, we are trying to go but we have been having a lot of rain in the valley and snow in the mountains for the last few weeks.
The small heater only has one setting whereas the little floor model does have a high and a low setting. I probably could run both of them because when I wired my van, I used 12/2 house wiring or the equivalent in round extension cord type wire so I think it would be heavy enough. I have never needed more than the little 1500 watt even when it was below freezing outside. So I will probably use one or the other, whichever is more convenient. We cover all the windows and windshield with custom cut Reflectix Al insulation to fit each window. That not only insulates it keeps the light out, so we can sleep in til noon if we wanted. Growing up on the farm as I did means I usually get up early even when I don't need to.
