Black95
Mar 04, 2021Explorer II
KaLvan wrote:
Really have enjoyed reading through your post and all you have done. We are doing a similar build on a 2014 Chevy Passenger Van. We put a 3/4 inch plywood floor down for our base. We are curious how you have attached your cabinet and bed into the van. At this point, we plan to leave all the factory walls in place, so don't have points of attachment in the van walls, just the plywood floor we have installed.
Also, by any chance, do you know where in the back passenger area there are airbags installed? We don't want to inadvertently set those off with our build!
I did not remove any of the floor nor the passenger seat brackets in the back of the van. I used them to mount my bed frame and my kitchen unit.
I made some brackets very similar to the picture below and mounted the top three holes to my bed frame and kitchen unit so they were positioned over the top of the seat brackets.
I pulled the locking pins out of the seat brackets in the floor, then slid my fabricated brackets down into them so the locking pin would engage the single hole in my brackets and locked the pins in place.
For the rest of the van floor area that had floor seat brackets that I did not use, I ordered a special piece of carpet with seamed edges like floor mats and put it down to cover up any exposed, unused floor seat brackets.
I will do some research on my van and the service manuals to see if I can locate the passenger airbags and get back to you on that in another message.
