Mondooker wrote:
One comment that overlooked from 2gypsies when he said, "The fewer slides you have on the patio side is better for use of your patio"! That's another one of those things I'd of not thought of but how true it is. I'll also make sure I don't buy a coach with the kitchen on the slide. That just seems like trouble!
The slides are not that invasive. The slides sit rather high and you can sit under the slide in a chair (depending on the coach). The space that you gain on the inside, to me, is more important than what you might lose outside.
You are in the coach more than you are outside. A kitchen in the slide is really a non-issue. Get the floor plan that works best for your family.
MM.
