MountainAir05 wrote:
I do not see anywhere they have replaced the gasket. What year is this unit and who made it.
As far as I know, there is no gasket. The tech at the company that I am working with says they only use sealant. It is a 2015 Newmar Ventana 4002.
way2roll wrote:
Playing Devil's advocate - you let a LOT of time lapse between repairs and not immediately validating the work had been done properly and didn't leak again. Seems like after getting it fixed you let it sit and didn't monitor for leaks right away. I understand extenuating circumstances, but after it leaked again after the first fix I would have demanded a thorough leak test the same day on the next fix. After the second time I would have escalated and sought to have them start over. If I am reading it right, 3 years and you've only had it fixed 3 times, that's a long time between repairs.
Yes and I agree I did not follow up. However, I was told by the tech trying to fix the leaks that from his company it is a lifetime warranty on installation. I don't think he was supposed to say that, but he did. Also if they did not want to honor a warranty they should have told me they will not try to fix it because the warranty is expired. The last attempt was last Thursday.
Kent
N6WT
