dougrainer wrote:
NC6B wrote:
Tom/Barb wrote:
I'd have a auto glass company remove the glass and clean all of the old sealer off and see if the glass fits properly.
you will have to remove it anyway, give it a try.
I was told by the tech, "if they remove the windshield it will break".
Yes, in most cases, pulling a CORRECTLY SEALED and installed Windshield may break when removing. Since they failed to correctly seal/adhere the Glass, I doubt it will break. An Attorney will cost MORE than just paying for a new windshield. Your best bet is to have a good Shop remove and reinstall or if it breaks, install new glass. Then sue in small claims court for the cost of the correct repair. Also, contac your RV Insurance company to see if your coverage will pay for a new windshield. Doug
Doug
Thanks for this suggestion.
I have had an idea that I got from noteven. I will do an air pressure test. I can seal the area around the top of the windshield with heavy plastic I have. Then I will hook up my shop vac to blow air into it. I will then put soapy water on the outside to see if there are any leaks.
Kent
N6WT
