ncrowley wrote:
Another question: we test drove a View and there was a lot of noise inside the coach. There was a lot of creaking and banging and rattling. I am not sure if the issue is that things have not been tightened up or tied down or not.
What mileage could I expect towing a Jeep at 4500 pounds?
Was this a new one or one with somebody's belongings in it? Ours is pretty quiet as far as RVs go. We pack to keep the noise down too.
As far as towing a 4500 lb Jeep, if you are at max gross weight for the RV (and you will be), you will be exceeding the combined weight rating.
RV gross weight is 11,000 and max combined weight is 15,000. That leaves 4,000 to tow.
Towing we get about 14 mpg but it varies wildly depending on winds and speed.
