PastorCharlie
Aug 11, 2013Explorer
dougrainer wrote:MrWizard wrote:
there could be a faulty transfer switch ( automatic 'power source' switching relay )
but it sounds like operator error
you can use ONLY ONE power source
you can use shore power, the generator, or the inverter-powered by the batteries
ONLY ONE not two at the same time
the freedom 20 'combo charger/inverter' will switch from inverting to charging with 120v 'pass thru' using shore or genset, anytime there is 120vac power available
you cannot use genset and shore power at the same time
You CAN use Shore and Gen set at the same time. BUT, only the Gen set will be supplying power to the RV. Doug
Correct. When both are activated the automatic transfer switch will default to generator and disconnect shore power.
38,709 PostsLatest Activity: Mar 12, 2025
