ratfink09's avatar
ratfink09
New F-53 Chassis Mods for new Class A
We are planning on buying a Class A gas motorhome in the fall. Currently we have a Class C motorhome with an E-450 chassis. I had Hellwig sway bars front and back and Bilstein shocks installed due to poor handling on the Class C and an alignment which all made a big difference in handling. We are planning a several month trip soon after we get our Class A. My thought is just bite the bullet and have the chassis upgrades done before we take delivery since we will be hitting road pretty soon after delivery. What does everyone think?
  • If you are several months away from even selecting a new unit and have already convinced yourself you will be dissatisfied with whatever you choose, I know some aftermarket accessory salesmen that would like to meet you. Seriously, I think the driveability of the newer Class A units may surprise you. It did me.
  • mikim wrote:
    Making the mods will make the ride so much better. Also, have the 4-corners weighed and adjust the tire pressure accordingly. Just cost us $ 7,000 at Henderson's Line-Up in Grants Pass, OR.
    Seems like a lot of $$$, what did they do?
    Fred
  • Consider the F 53 chassis on 22.5 wheels, it will be the better ride. Also the 24,000 lb. chassis has the most tow capacity, i.e. 6,000 lbs. vs. 4,000 lbs. for the 22,000 and 26,000 lbs. chassis.
  • I'd drive it for a while before I started dropping money on upgrades. You may not need them. I think the newer F53 already come with bilstein shocks, and a rear panard bar. And it will drive different then your class c.
  • It's all in what you want to spend. :) The mods done up front may be the way to go if it is worth it to you. The question is, have you had a problem with it yet? I mean, you ARE going into a completely different coach and may not have the 'feel' of it yet. There may be no problem to begin with.
  • Making the mods will make the ride so much better. Also, have the 4-corners weighed and adjust the tire pressure accordingly. Just cost us $ 7,000 at Henderson's Line-Up in Grants Pass, OR.
