RVER wrote:
I have a used Motorhome circa 2003 Newmar, got new TVs put in but now do I use the selection box or is it just the menu of AIR or Cable in TV menu and where is the cable attached to on the selection box that is in the rig? The installer did not screw in the cable to back of the selector box so I want to screw it in the right place, and we put a tv in back bedroom so hope that is plugged into the right place so I can play the two tvs on different channels.
You will still need to have the selection box in place to switch between Cable and OTA TV assuming no other modifications were made. The coax that runs to each TV will be connected to the box one going to the output that says TV and the other to the output that says TV2. This box may contain the OTA amplifier or it could be separate but the box would be necessary due to the way the coach was originally wired. There should then be a coax coming from the outside Cable connection that plugs into the back of the box and is labeled Cable and the coax that runs to the antenna on the roof will plug into the connection on the back labeled Ant (antenna).
