Nomadac
Nov 18, 2015Explorer
Jim@HiTek wrote:
I'll just mention that many, many people don't bother with the Pink Stuff except to pour it down the drains to fill the traps and put a little in the bottoms of the grey and black tanks.
The reason is that it takes so much water to get the pink taste and color out of the fresh water in the spring. And with most of the US in drought conditions, it's just prudent to use the 'Air' method for your fresh water lines.
Air method uses an inexpensive tire pump to blow water out of the fresh water lines starting at the inside shower head. I just open the lowest faucet and blow it out there. Also remove the pump and drain it.
I use Pink Stuff after I blow out my lines. It is easy to eliminate the pink taste in the Spring by sanitizing the water system which I do. You may find you cannot get all of the water out of the valve that is operated by the foot pedal in the toilet, or the valve in the back of the Refrigerator that controls the water to the Ice maker. All it takes is a small amount of water in either valve and you will be replacing, as I learned the hard way. One-two gal. of Pink Stuff is very inexpensive IMO to be sure.
38,763 PostsLatest Activity: Dec 05, 2025
