pianotuna
Aug 09, 2020Nomad III
Hi,
On a previous RV I solved corner leaks by injecting Great Stuff foam. Do it from inside the RV. Drill a hole just big enough for the tube to fit. USE LOTS!
If you have to trim the foam on the outside of the RV, cover it with Eterna Bond. When you trim the foam it becomes open cell--that is why it needs to be covered.
Go in peace and leak no more.
