dougrainer
Apr 20, 2016Nomad
The Slide mechanism in the Storage area will have to be aligned. On a Newmar, you loosen the Trans Torque bushings and push the room to be even(using a tape measure) then tighten the Trans-torque bushings. No other way to do it. If the slide lock is bowed and bent, it is best to replace as once bent it will be difficult to get it to lock tight in place. If you do not know how to align the room, it is best to go to a Newmar Service facility. We charge 1.0 hour labor to align rooms on Newmar's when this happens. The replacement of the Lock arm cab run from .5 to 1.0 depending on how easy it is to get to the wall mount screws. Doug
