Deano56 wrote:
cvbdsl wrote:
Just a thought on the noise, was this when you were inside or did you check with the hood open?
Reason I'm asking is that when I bought my 2003 DSDP 4005 the noise inside from the generator was very loud and like you I thought this was a deal breaker. However when checking outside I found that the hood latch was loose and hood vibrating was causing the noise. Just putting my hand on the hood stopped most of the noise. A couple of simple adjustments on the latch stopped the noise.
chris
actually I was in the coach when they started the generator to turn on the A/C. It really sounds like bad valve adjustment like I had on a old Volvo, I would have to adjust them from time to time as they would get noisy
