Tom_Barb's avatar
Tom_Barb
no high beam headlights
Things we have already done.
1 changed both headlights, confirmed with continuity check.
2 replaced headlight switch. still no high beams.
3 replaced the relay (part number - H8002B).
4 checked every fuse in the coach. (continuity confirmed)
5. checked for power at the relay in both directions. power is good.
2000 Newmar mountain aire.
low beams work, as well as parking lights as well as the dash dimmer.
suggestions ?
  • Am guessing you have a multi-function turn signal switch assembly. Have you checked for control voltage to the high beam relay? Does your turn signal lever allow for pulling up for energizing the high beams and down to lock in high beams?
