DSDP_Don
Mar 28, 2015Explorer
sdpadrefan.....Often electrical issues like this are the result of a bad ground, especially since you had corrosion on the relay once before. Just to make sure, I would go out and connect another ground to the HWH unit with a small jumper cable and see if the issue still exists.
I remembered reading somewhere where the mounting points on the HWH unit corroded and loss ground.
38,763 PostsLatest Activity: Dec 05, 2025
