enblethen wrote:
Sprig ask how to test fuses.
Looking at a fuse doesn't always work.
I believe the OP found his main fuse that powered his two rows of fuses.
Absolutely correct! Many, many technicians will tell you that an "appearance" of a fuse is not a forgone conclusion that a fuse in intact. I've only seen it once myself but, it does exist. Yes, about 99.999% of them actually "blow" and show a burnt section of the link inside the fuse so, the appearance does give those away. So, if in doubt, DO CHECK BOTH SIDES OF THE FUSE IN QUESTION. At least you'll definitely rule that out.
Scott
