Here's some more info.
Went to start my motorhome last Friday for us to go away for a few days and when I turn the key on nothing lights up on the dash, the leveling panel also doesn't come on and the generator doesn't start from the panel inside or at the generator. Everything was working on Saturday when I started it and moved it, I did disconnect the batteries and cleaned the cables but I've doubled and tripled checked that everything is hooked back up and hooked up correctly.
I don't even see any power coming to the dis-connect switch, both batteries are showing 12v, I don't know where to check next.
- way2rollOct 25, 2024Trailblazer
The fact that everything was working fine, then you disconnected the batteries to clean etc, and now it doesn't work, leads me to think you didn't hook it back up properly or you blew a fuse somewhere.
- HughesiiOct 25, 2024Explorer
I've double and triple checked the batteries that they're connected right . I'm guessing a fuse also but can't find any and can't find any info as to where they are located. Any guess or pictures showing them would be great.
- pianotunaOct 25, 2024Nomad III
Hi,
Try attaching a jumper cable between the negative post of the battery and an alternative ground on the chassis.
