Executive45
Feb 22, 2016Explorer III
1. Ball bearing fans. Don't waste your money on cheap non bearing Chinese fans.
2. Fridge just needs to be moved forward far enough to access the back of the fridge thru the outside access hatch. Being a contortionist will help.
3. Any four hole fan will fit as long as they are the correct size. Usually 4".
4. Make sure they are 12VDC.
5. I'll get the number of the ones I used and post a picture later today.
6. Whoever did your cooling unit replacement sure did you a disservice by not replacing them at the same time. Every CU mfg recommends that.
7. If you can't find them anywhere else, HERE is a place to get them....Dennis
Below is a pic of the fans I used. Cost was $4.95 each. Since we spend time in Texas and Arizona I had added four extra ones on the roof. I have pics of that if you want them. I have since pulled the Notsocold out and replaced it with the Samsung 197 residential....:)
