Hedgehog's avatar
Hedgehog
Norcold 1200 not cold enough
I had the cooling unit replaced on my Norcold 1200 last fall due to constant failures with the bypass module that was put in under recall a few years ago. The RV shop replaced the cooling unit with another Norcold unit and not a Amish one. Since this unit was Norcold, it came with one of those stupid bypass boxes that I was trying to get away from in the first place. Anyway, last week the stupid box tripped again so I swapped it out. Since then, the fridge is running but I am now camping and I noticed the ice cream in the freezer is very soft. The control on the front is set to the max (9) so last night I put a thermometer in the freezer and found it to be 4 degrees. The fridge part is running around 36 degrees. What should I do now or is this normal?
