campingman55's avatar
campingman55
norcold 1200 rlm code he
i have a 2005 vectra with a 1200 rlm and when plugged in to 50 amp the fridge works right it also works when thethw gen runs it works all right now here is the problem when plugged in a 110 outlet at home and i turn on the fridge to ac i get a he code that is the the only time i get is when i plugged into a 110 outlet need help
  • HE code is for "Heat Element" ... usually means the heat element is burned out.
    That was from a Google search on the Norcold "1200 HE fault code".
