I have a National 06 sea Breeze and my safety switch put on from the recall on the fridge shut the fridge off! the light is on when I took the cover off the out side of the fridge! I can't remember wh...
Totally Understood I know all about the cooling units failing for one reason or another usually because people for one reason or another operate them out of the factory level specs causing failures If I wanted to I could show you a picture of thousands upon thousands of RF with leaked out cooling units or blown compressors
