usersmanual
Nov 12, 2016Explorer
Nutinelse2do wrote:
We just bought an 06 Newmar, that the mod was not done on yet.
I called Norcold to check the sn's, and the lady I spoke to was mortified the mod was not done yet.
She overnighted the appropriate hardware to an rv repair facility by us, to have it installed asap.
We are having it replaced with a residential next week. Asked the RV repair facility about the danger until then, and he said it is caused while the fridge is on propane, not electricity. He did a little inspection, and said he sees no signs of any overheating at all, so will stay plugged in to 50amp till we do the change.
that's not true.There is a small possibility of a fire and its caused when and if the ammonia leaks from a failed cooling unit and you leave the fridge operating on lpg or 120V and it overheats from trying to cool is where there can be a fire danger as I understand things.The so called mod your having done is a sensor that's designed to detect a over heating unit and shut off the 12V power supply
