usersmanual
Nov 17, 2016Explorer
grldst wrote:
We just bought a used 2002 Executive with the Norcold 1200 LRIM...fridge works great, there is no sign of the black box with the red light.
Should I be concerned.... apparently this fridge has been working for some time without any issues.
I'm inclined to side with "dougrainer" on this issue.
take the cooling unit serial number and see if its in the recall
not every 1200/1210 unit was.Iam pretty sure you can get a free kit installed even if its not but at least you will know
The recall kit kills the 12V power that runs the control board if in the event it was overheating
In general these fridges work very well but its 14 years old.As long as its never been run off level its most likely in good condition
have the insulation removed in the burner area and check for heavy rust corrosion.If not notable its good if heavy corrosion replace cooling unit
38,782 PostsLatest Activity: Sep 20, 2026
