Norcold refrigerator not working need help leaving in 5 days. Went out to turn on the frig today no luck. placed on electric it trows the gfi breaker and goes to LP. Ignition lites the pilot then igni...
Sounds like you have 2 problems both are an easy fix. A blocked burner or rusted out burner on the gas side. Start by cleaning the burner and see if any of the slots are rusted out if so it will need to be replaced. The GFI tripping as others have said requires a new heating element which is probably rusted in place and will require long needle nose pliers to wiggle it back and forth to remove it. Good luck.
