mark734
Jul 10, 2015Explorer
norcold door
the plastic sleeve holding bottom of door in place broke anybody heard of a fix for this thanks jw thompson
dfm wrote:did you take pix?
Last week my DW opened the fridge door and had the door in her hand "off the hinge" !
Just repaired/rebuilt it to make it bulletproof. The back side of the plastic sleeve that the pin fits into broke on mine. Probably too much weight in the door compartments.
The plastic was broken cleanly so I was able to super glue the piece back in. Then I got an aluminum flat piece, 2 inches by 22 inches by 1/8 inch. Drilled a hole to precisely match the size of the pin and then screws the aluminum to the bottom of the fridge door panel. This reinforces the plastic sleeve so I doubt it will ever break again. The aluminum edge can be seen at the front of the door when closed but it looks like factory o e m.
alid wrote:
read this thread.
norcold door
