bgosden's avatar
bgosden
Norcold N611 five flashes
Hello!
Brand new to the RV world, and we have a couple things we could use some help on. I will post as separate topics to keep things separate.
The first issue is our new to us Class A has a Norcold N611 fridge. {2003 Winnebago Itasca Sunova) Previous owners said no issues, but since we bought it we have had it fault coding the five flashes every day. We know how to reset the control board with the insulated wire, and have done so each time.
On reset, the fridge will almost complete a cooling cycle, then codes again. Five flashes which according to documentation means no cooling. It happens on both Electric or when running on gas. No ammonia smell, no yellow powder.
We have replaced the heating element and power cord, cleaned the igniter, same behavior.
We tested the thermister using a meter and the ice test, and it tested fine.
We replaced the control board, and the fridge worked for the first time for days! Ice cold freezer, cold fridge, no flashing- Then after about 4 days it started again.
WE attempted to inspect the flu to see if there is a blockage, but it appears the flu has some sort of insulation inside that we were afraid to disrupt as it looked like it is there intentionally.
Any ideas before we give in and have it fixed at a service center?
Thanks so much!
  • I believe your two issues are connected. The fridge still needs 12VDC power even when on propane. The fact you're having issues with your battery bank leads me to believe your problem(s) lie there. Start with checking your battery bank with a meter. You've been given good advice on how to check that. I believe you said you replaced the batteries, correct? If so, make sure you installed them correctly. Make sure your disconnect switch is correct also. Do you have and know how to use, a meter?...Dennis
