Doug_and_Cassi_'s avatar
Apr 30, 2013
Norcold not switching to propane in auto mode
I had this problem once before and it "fixed" itself. Today it did it again.
Unhooked to travel and everything went fine. Switched right to propane. We stopped about an hour later and opened the fridge door. No light and when we shut the door the door open buzzer started going off. Turned fridge off then back on and buzzer went off. Two or three minutes later did it again. W turned it off then back on.
Finally turned on the inverter and continued on down the road with fridge okay. Hooked up at next stop and working fine.
We had a new cooling unit installed in December and it was working fine until today.
My thought is the main board. Any other suggestions or ideas?
Is it something I can change?
Thanks in advance.
  • Are you getting a fault code? Check the owners manual and if need be a service manual is available at http://bryantrv.com/docs2/docs/ncoldnnewnseries.pdf
    The service manual has been very helpful to me in the past. Saved me a large repair bill when I discovered it was just a fuse. The service manual goes into much more detail than the owners manual. Good luck. Safe travels.
