Winnipeg
Oct 07, 2016Explorer
Not enough batteries
We are kicking tires on a new MH. Yes, we want a new gas coach, so suggesting a used DP to solve this particular question is not on track.
The Allegro 32 gas coach has our eye, but we are wondering about only 2 batteries. It appears that almost all upper level gas coaches have residential fridges these days, and they mostly all have only 2 batteries. It doesn't seam like enough. We mostly desert camp without hookups.
When residential fridges first started showing up in DP's about 10 years ago, they were adding 2 extra batteries in addition to the typical 4 batteries that DP's had. LED lights have reduced the load, and maybe 6 batteries is not necessary, but 2 seams too little.
The problem is complicated by the fact that simply adding more batteries does not appear to be an easy task. The two that come with it are under the steps. Maybe replace those with lithium? The storage compartments are not very heavy gauge, so simply putting batteries in there may not be a good idea without reinforcing things.
Any comments on dry camping with residential fridge & only 2 batteries? What happens if your furnace comes on and further taxes the batteries? Any good battery upgrade solutions?
