Scott_M
Sep 19, 2020Explorer
Odd Electric Step Problem
Our step has been working fine for a couple of years. Today, I was giving the RV a bath and went to back it into the carport and I heard the steps go out. I turned the RV off and the steps go in.
Even with the step over ride switch off, the steps extend when the you turn the ignition key to the start position.
With the ignition off and the step switch on the steps work fine. Extend when the door opens, retract when the door closes. Turn the step switch off while extended, they stay extended.
Any thoughts? It doesn't appear to be the motor. Maybe the controller module? Ignition interlock?
