bsinmich
Dec 08, 2020Explorer
It is that starting for a few minutes to warm it up and then shutting it off is what helps to build up moisture in the oil. Getting the whole engine totally warmed up will get the moisture hot enough to evaporate. UNLESS YOU HAVE EXCESSIVE MOISTURE DILUTING YOUR OIL I WOULDN'T WORRY ABOUT IT.
38,782 PostsLatest Activity: Aug 31, 2026
