Sir_TravellerExplorerDec 08, 2020Oil change + replace battery, which comes first ?Hello Everyone… I have a 2003 Ford F-550 RV ( four winds hurricane 6.8L ) , I want to replace the chassis battery and do oil change , which one should I do first? Take into consideration the last o...Show More
midnightsadieExplorer IIDec 08, 2020might air up the tires,check for dry rot. changing filter easy should be a spin on. put some sea foam in the gas tank.
Related ContentAG battery switchoverBattery Size (replacing)BAttery replacement.Replacement Lights for TTBattery Replacement?
