- NinerBikesExplorerI would look underneath the engine, and see what brand and number oil filter is already on there. Cross reference it first via Google, then go buy the parts local. Oil should be pretty common, it takes what 5 or 6 quarts? What does the chassis manual say that came with the owner's manual?
- BTPO1ExplorerI normally do my own oil changes due to the cost at oil change places. I go to Autozone and look up a Ford F550 V10 engine and use the part numbers for filters. Your oil fill cap should tell you what type of oil to use. I can't help you on the capacity though. You might try asking the Ford dealer in your area, they usually will tell you. JMO
- 1492ModeratorMoved from Forum Technical Support
38,707 PostsLatest Activity: Feb 18, 2025
