egh33
Mar 25, 2014Explorer
Oil Hubs ( front)
Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...
rgatijnet1 wrote:
There is a rubber plug in the center. With the plug removed, the bottom of that hole is the maximum amount of oil that you should put in. Any more and it will just run out on the ground.
