- J_WalkerExplorerMy Freightliner uses 80W 90 oil in the front wheel bearings.
- wolfe10ExplorerYes, the majority of larger RV's as well as most all OTR trucks use oil to lube the front wheel bearings (and trailer bearings on OTR trucks).
Sure a lot easier to change the oil than to remove the hub and repack with grease. - Community AlumniNot applicableGo here page 56
Freightliner Know your Chassis
it shows a front oil filled bearing I thought one picture would be worth a thousand words.
JimR - Mr_Mark1ExplorerWe have bearings on the front so no hub oil. We just need to have them done every 30,000 miles which is coming up at our 60,000 mile service. We DO have hug oil on the rear axle which is checked every 5,000 miles when I have he chassis lubed.
MM. - RFCN2ExplorerMine takes 90 weight gear oil.
- kennyd63Explorer
kennyd63 wrote:
Hello-
What is this wheel hub oil/ and does every MH has it? no maual:o
Thank you,
Thanks for your answer shaneperch!! - sch911Explorer
38,782 PostsLatest Activity: Sep 19, 2026
