egh33ExplorerMar 25, 2014Oil Hubs ( front)Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...Show More
rvtenExplorerMar 25, 2014I used to fill mine to the bottom of the hole.Side plug is the drain.You can go to irv2.com and Ho to the Workhorse forum.Check there.
Related Content4x4 front hubOil filled front hubsoil filled hubs/front wheelsWheel hub oilWheel Hub oil!!
